MPC5646C Demo Code
MPC5646C Demo Code
sandrine_labois
I use MPC5646C on Green Hills - Multi, i build demo code "Example MPC5646C PinToggleStationery CW210" but it not run. Where do find demo code of MPC5646C on Green Hills - Multi ?
Thanks & Regards
S. Labois
Tags (2)
davidtosenovjan
Hi, we have been creating our software examples for MPC55xx and MPC56xx in CodeWarrior 2.10 or 10.x.
MPC57xx examples was initially based on GHS6.14 as no FSL/NXP compiler were available in certain time period, currently we are using also S32 design studio.
If you need MPC56xx example based on CodeWarrior in run GreenHills environment, you will have to port it on your side as we usually prefer solution based on our compiler.
