USB camera not detected
Question asked by JOHN JOHN on Mar 1, 2017
Latest reply on Mar 5, 2017 by igorpadykov
   I am currently using the SABRE AI board with the BCM89810 phy card. The card is getting detected and I am able to stream from the board to a PC(using a technica converter) using gstreamer. But when I try to connect a USB camera, the camera is not getting detected in /dev. This happened only after applying the patches for BCM89810. It worked fine in the kernel in which the patch was not applied. How can we detect the usb camera with the new kernel (after applying bcm patch).
Thank you,
John Jacob
