J-Link GDB Server failed
hongshiong
I encounter an issue of "J-Link GDB Server failed:
Could not connect to target. Please check if target is powered and if ribbon cable is plugged properly." It happens when i load my code(lets say print out Hello world) and using thread to delay, after i terminated the IDE and reload the my code then this issue happen. If i print out Hello world in while loop but without using thread delay, this problem doesn't happen, may i know why?
mesdouaabderraz
hi, i have same problem, Do you had resolve it?
