Hi All,
I am able to perform configure attribute reporting successfully.
I have tried by configuring attribute reporting for ON/OFF state (ON/OFF cluster - 0x0006) with LED bulb device using ZGWUI tool. But to perform configure attribute reporting, we must have to perform binding between end device and coordinator. Because end device does not know the destination address to whom it sends the attribute change value. So end device gets information regarding destination address from binding table.
After performing binding between end device and coordinator, coordinator can configure attribute reporting for end device's particular attribute. Once attribute value changed, coordinator will receive notification from end device.
Jainil Shah
Hi Jainil,
I set config report to get the sesor battery remaining.
I have tried by configuring attribute reporting for my sensor with ZGWUI tool (cluser 0x0001 power config ,attribute ID 0x0021 battery remaining)
But it return the error (error code 0x0A)
I guess I was set the direction TO SERVER ,because the direction TO CLIENT was return success even if it did not work
can you please help me out?
