KIT912J637EVME TEMPLATE
henriquekuehne
I just bought the evaluation board KIT912J637EVME and the item CD912J637 referenced on User Manual http://www.nxp.com/assets/documents/data/en/user-guides/KT912J637UG.pdf  is not supplied anymore.
Could someone send me the template to project using the MM912J637 component for battery monitoring?
Thank you in advance,
Henrique.
david_diaz
Hello Henrique,
Please review the file attached to this response. You may find the template requested.
I hope this material helps.
David
FlavioAlves
Can we find the firmware implementation of the this presentation: http://cache.freescale.com/files/training/doc/dwf/DWF13_AMF_AUT_T1043.pdf ?
There is a project located at the following thread: https://community.nxp.com/thread/319590 . With this project it is possible to capture voltage, current and temperature. But it doesn't implement SOC algorithm, in the same way as presented.
Can you give us some guidelines about how to have this implementation?
Flavio
henriquekuehne
Hello David,
Thank you very much for your help.
This is what I was looking for.
Unfortunately, I thought that it would have an example of Coulomb Counter implemented, but it does not have.
Thank you again and best regards,
Henrique.
david_diaz
Hello Henrique,
David
