How does Create BLDC control model with S32K144 ?
fengwang
Hello Engineer ,
I want to create B
LDC control model with S32K144 , through FreeMaster to view motor speed , DC voltage and so on,
Like this :
What is the right procedure to do this work? Many thanks.Mandar JoshiisaacavilaDhaval ShahRHinnen
Feng
Abdel
Hi together,
where i do find the MCAT app for BLDC Motor control using Hall Sensor and S32K144? Thank u in Advance.
best regards
Abdel
isaacavila
Hello Feng,
Here you can find similar DEMO for KEA: 3-phase Sensorless BLDC Motor Control RD|NXP .
You can use it as reference and try to implement it by using S32K144.
I hope this can help you!
Isaac
