There happen some error When I use S32 DS open WDOG_Example
_simple_
I  use S32 Design Studio for ARM Version: 1.3  Build id: 170119,There happen some error When I use S32 DS open WDOG_Example? No such file or directory main.c /WDOG_Example/Sources line 60 C/C++ Problem,Who can help me solve this problem?
Thanks!
raresvasile
It seems that PEx code was not generated. Please try to generate the configuration structures and file links by clicking on Project -> Generate Processor Expert Code.
Rares
_simple_
Thanks,According to what you said, I try it, But the problem still exists.
Thanks for your help
raresvasile
What version of the SDK are you using?
Can you attach the project?
_simple_
The SDK version is S32 Design Studio for ARM Version: 1.3
File->Import->S32DS Example Project
