CodeWarrior Flash Programmer License
justinjonas
I have a valid evaluation license which shows up when I open the 'Freescale Licenses' window in CodeWarrior.
I am trying to run the Flash Programmer using gdb, and I get the following errors:
(gdb) source ../../gdb_extensions/flash/cwflash.py
Starting flash programmer services...
Starting local server...
Successfully started gdb server 127.0.0.1:45000.
Set gdb remote timeout to 7200
Connecting to target...
Using LS1012A SoC
Using CWTAP connected to local usb port
Using jtag speed 16000
Connecting to probe...
GTA: license checkout failed.
connection failed
Target connection failed. Please re-check the settings.
Processor: LS1012A
Probe: CodeWarrior TAP
Additional error details:
[GTA: license checkout failed]
Closing debugger server...
Error: fail to start flash programming services.
Can anyone help me to fix this issue?
Thanks for your help!
