Hello Guys,
I have bought a LPCXPRESSO1769 with cmsis-dap from embedded artists and I already spend a few days of research.
As always I wanted to start blinking the onboard RGB LED. I already managed to acces the correct registers with the library "lpc17xx.h" and toggle the appropriate pins with an example I have found online.
Before I go any further I really want to understand what I am doing.
The example uses the following registers and syntax:
LPC_PINCON->PINSEL7 = 0x000000;
LPC_GPIO3->FIODIR = 0xffffffff;
In the user manual UM10360 I can find the defintion of the PINSEL register and the function of FIODIR and the definition of the PIN CONTROL MODULE. But nowhere the syntax "LPC_PINCON->..." or "LPC_GPIO[n]->" is used. So how do I know what syntax to use in which situation? For me as a beginner the "lpc17xx.h" does not really help me. So what I am searching for is a reference manual with detailed syntax explanation.
I also tried to find such a manual for the LPCOpen libraries with no luck.
Can anybody give me a hint?
Your help is very much appreciated!
Denis
In addition, please check the following document, I hope this helps.
https://community.nxp.com/docs/DOC-333169
Soledad
You already have the User's Manual. Perhaps what you need is to download the LPCOpen example code for the LPC17xx. See here:
Thanks and regards,
LPCXpresso Support
