Question about FRDM-KL26Z installation
carlosparedes
Hi, after installing the FRDM-KL26Z board successfully, I had to format my computer and I've tried to reinstall it again following all the steps but then the Out-of-box demo is not working anymore and also, after installing all the software, when I try running the Tera Term tutorial, nothing happens when the MS-DOS black window pops up. What can I do to get it working again? Is it any way to restore it?
Many thanks in advance for your help.
miduo
From what your description, this issue is not related with the Fredom board, but the driver of your cumputer. For example, you may download and install the P&E OpenSDA USB driver here:P&E Microcomputer Systems: Over 30 years as an Industry leader in Embedded Systems Development Tools...
