No SDK support for FRDM-KE04Z or KE04Z?
dstraight
Using this link:
https://mcuxpresso.nxp.com/en/select
I was unable to find the
FRDM-KE04
or its processor
KE04
I've Tried a few search strings such as - KE04, MKE04, and  MKE04Z8
Is there an SDK for the MKE04Z8 (or the Freedom Board)?
David
MarekTrmac
Hi David,
based on document located here: https://community.nxp.com/docs/DOC-333073 it seems SDK support is not planned.
Marek
mjbcswitzerland
Specialist V
http://www.utasker.com/kinetis.html
This supports almost all parts, including KE04, with device simulation and the ability to essentially run the same code on a KE04 up to a K70 without porting effort.
Mark
