Register Protection
Register Protection
xiaobozheng
hi:
 is there any Register Protection (REG_PROT)(mpc5744p) software sample or document?  thanks!
lukaszadrapa
see the Appendix A on page 2843 in the reference manual:
http://www.nxp.com/assets/documents/data/en/reference-manuals/MPC5744PRM.pdf
There's a list of registers which can be protected. There's no INTC_0.BCR, so the lock bits are not implemented and the write access will lead to bus error.
Lukas
lukaszadrapa
take a look at
https://community.nxp.com/message/830141
Lukas
xiaobozheng
there is another problem,
  CLR_SOFTLOCK32(INTC_0.BCR.R);
  GET_SOFTLOCK(INTC_0.BCR.R, lock);
  this two function will cause an reset , means we can not access 0xfc043800 ( the Soft Lock Bits area of INIC module). why this is happen?
lukaszadrapa
Lukas
