phy reset time out ,no ethernet link
longqiluo
hello,I am confusing about 1000M ethernet connection. my CPU is p1023,  phy is ar8035, the schemitic is largely same  as P1023 reference schemetic. At present stage, I can boot linux nomally. I try to use FM1@DTSEC1 as ethernet device in uboot prompt,but it seems present no link. I can test stable 25M clock from AR8035 pin clk_25M,and I can access the register of phy ,so I think the hardware is ok.When  uboot booting, there always present "phy reset time out", does it means the reset of phy have problem or some configuration I am not awared? Detail problem see attached.
Attachment: POWER_V2.PDF is about phy 8035 designing
                      P1023designing_v4 is about CPU side
                       PHY_PRO.txt is about uboot log and linux log and some environment variable setting.
                        DEVDISR.jpg and PORDEVSR.jpg are register of P1023 ,regarding to DTSEC setting and power-on status.
could anybody analysize for me? thank you in advance! if you have any information which could be help, please send my email: luolongqi2014@stu.xjtu.edu.cn
Original Attachment has been moved to: PHY_problem.rar
ufedor
How the DTSEC is configured?
Note that for 1000M operation the RGMII clock has to be 125MHz.
longqiluo
Yeah, the DTSEC1 is configured as RGMII mode(you could see the register
DEVDISR,PORDEVSR) , the phy power -on strapping as attached . I do test 25MHz
clock ai pin CLK_25M, as you mentiioned, it should be 125M.So, please help me
check the schemitic about PHY ar8035(though it is the same as your offical
shemetic).
a
body {
font-family: Helvetica, Arial, sans-serif;
-webkit-text-size-adjust: 100%;
/* Webkit */
h1, h2, h3, h4, h5, h6, p, hr {
-webkit-margin-before: 0;
-webkit-margin-after: 0;
-webkit-margin-start: 0;
-webkit-margin-end: 0;
.button td {
background-image: -moz-linear-gradient(top, #75B7E3 0%, #5498D6 50%, #408BD0
51%, #387AC8 100%) !important;
background-image: -webkit-gradient(linear, left top, left bottom, color-stop(
0%,#75B7E3), color-stop(50%,#5498D6), color-stop(51%,#408BD0), color-stop(100%,#
387AC8)) !important;
-webkit-box-shadow: inset 0 1px 0 #74b9de, 0 1px 3px rgba(0,0,0,.3) !
important;
-moz-box-shadow: inset 0 1px 0 #74b9de, 0 1px 3px rgba(0,0,0,.3) !important;
ufedor д:
NXP Community
Re: phy reset time out ,no ethernet link
reply from ufedor in QorIQ Processing Platforms - View the full discussion
> I can test stable 25M clock from AR8035 pin clk_25MHow the DTSEC is
configured?Note that for 1000M operation the RGMII clock has to be 125MHz.
Reply to this message by replying to this email, or go to the message on NXP
Community
Start a new discussion in QorIQ Processing Platforms by email or at NXP
Community
Following Re: phy reset time out ,no ethernet link in these streams:
Inbox
This email was sent by NXP Community because you are a
registered user.
You may unsubscribe instantly from NXP Community, or
adjust email frequency in your email preferences
ufedor
In the PHY datasheet it is written:
"NOTE: CLK_25M default outputs 25MHz, can be configured to 50MHz, 62.5MHz, or 125MHz by register MMD7 8016[4:3]."
Have you did the configuration?
longqiluo
no, I have not set MMD7 8016[4:3] , your advises could be considered. Except
this, I found the ethaddr=00:04:9F:02:87:0D, in AR8035 DATASHEET, it describles
the registers about local MAC address,as attached. Should i set it as ethaddr=
00:04:9F:02:87:0D ?:=> pribaudrate=9600bootargs=root=/dev/mtdblock2
rootfstype=jffs2 rw console=ttyS0,9600bootcmd=bootm 0xefb70000 -
0xeda50000bootdelay=3bootfile=uImageeth1addr=00:04:9F:02:87:0Dethact=
FM1@DTSEC1ethaddr=00:04:9F:02:87:0Cethprime=FM1@DTSEC1fman_ucode=
0xec000000gatewayip=192.168.1.1hwconfig=usb1:dr_mode=host,phy_type=ulpiipaddr=
192.168.1.19loadaddr=0xec002000serverip=192.168.1.20stderr=serialstdin=
serialstdout=serial
a
body {
/* Webkit */
.button td {
important;
ufedor д:
NXP Community
In the PHY datasheet it is written:"NOTE: CLK_25M default outputs 25MHz, can be
configured to 50MHz, 62.5MHz, or 125MHz by register MMD7 8016[4:3]."Have you
Community
Community
Inbox
registered user.
ufedor
> Except this
This is not needed.
longqiluo
dear engineer, I tried to write MMD7 8016[4:3], but itdoesn't work. i think
maybe my write operation is not right. here is my operation in uboot prompt:U-
Boot 2011.12-00064-gbfb0c9a-dirty (Feb 13 2017 - 20:29:47)
CPU0: P1023E, Version: 1.1, (0x80fe0011)Core: E500, Version: 5.1, (0x80212151)
Clock Configuration: CPU0:400 MHz, CPU1:400 MHz, CCB:266.667 MHz,
DDR:400 MHz (800 MT/s data rate) (Asynchronous), LBC:16.667 MHz
FMAN1: 266.667 MHzL1: D-cache 32 kB enabled I-cache 32 kB enabledBoard:
P1023 RDSI2C: readySPI: readyDRAM: 256 MiBFlash: 64 MiBL2: 256 KB
enabledNAND: fsl_elbc_nand: address did not match any chip selects0 MiBEEPROM:
Read failed.PCIe1: Root Complex of Slot 1, no link, regs @ 0xff60a000PCIe1: Bus
00 - 00PCIe2: Root Complex of Slot 2, no link, regs @ 0xff609000PCIe2: Bus 01 -
01PCIe3: Root Complex of Slot 3, no link, regs @ 0xff60b000PCIe3: Bus 02 - 02In:
serialOut: serialErr: serialNet: Fman1: Uploading microcode version
160.0.18PHY reset timed outFM1@DTSEC1 , FM1@DTSEC2Hit any key to stop
autoboot: 0 => mii infoPHY 0x05: OUI = 0x1374, Model = 0x07, Rev = 0x02,
1000baseX, HDXPHY 0x08: OUI = 0x0000, Model = 0x00, Rev = 0x00, 1000baseX, HDX=&
gt; mii write 0x05 0x0d 0x07=> mii write 0x05 0x0e 0x8016=> mii write
0x05 0x0d 0x4003=> mii read 0x05 0x0e 0000=> mii write 0x05 0x0e
0x0018=> mii read 0x05 0x0e 0000=> attachment is recommended in
AR8035 DATASHEET.please help me£¡ thank you !
a
body {
/* Webkit */
.button td {
important;
ufedor д:
NXP Community
> Except thisThis is not needed.
Community
Community
Inbox
registered user.
ufedor
Possible reference is function fecmxc_mii_postcall(int phy) in the:
Cross Reference: /denx/u-boot/board/freescale/mx6qarm2/mx6qarm2.c
longqiluo
thank ufedor, I followed you advises and now I can get 125M ai CLK_25M pin.but
still no link .I refered to the uboot -2011.12 source uboot/board/freescale/
p1023rds/p1023rds.c there is a statement:int board_eth_init(bd_t *bis)
100{
101 ccsr_gur_t *gur = (ccsr_gur_t *)CONFIG_SYS_MPC85xx_GUTS_ADDR;
102 struct fsl_pq_mdio_info dtsec_mdio_info;
103
104 /*
105 * Need to set dTSEC 1 pin multiplexing to TSEC. The default setting
106 * is not correct.
107 */
108 setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_TSEC1_1);
109
110 dtsec_mdio_info.regs =
111 (struct tsec_mii_mng *)CONFIG_SYS_FM1_DTSEC1_MDIO_ADDR;
112 dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; So , does the pmuxcr set as
MPC85XX_PMUXCR_TSEC1_1(0X10000000)? if does, the multiplexing is wrong, how
should I modified?
margin: 0;
padding: 0;
a
body {
/* Webkit */
.button td {
important;
ufedor 写:
NXP Community
Possible reference is function fecmxc_mii_postcall(int phy) in the:Cross
Community
Community
Inbox
registered user.
ufedor
PMUXCR[TSEC1_1] should be set to 1.
longqiluo
thank ufedor. Actually, I already set PMUXCR[TSEC1_1]=01, and PMUXCR[TSEC1_2]=
01, so read the PMUXCR(addr=0xff60_0000 + 0x00e0_0060=0xffe0_0060) =0x1400_0000,
like below :U-Boot 2011.12-00064-gbfb0c9a-dirty (Feb 18 2017 - 14:58:40)
1000baseX, FDXPHY 0x08: OUI = 0x0000, Model = 0x00, Rev = 0x00, 1000baseX, HDX=&
gt; md ff6e0060 1ff6e0060: 14000000 ....=> I refered to some others
configuration, should I configure DTSEC register(ECNTRL and MACCFG2)? if should,
what value?
a
body {
/* Webkit */
.button td {
important;
ufedor 写:
NXP Community
Community
Community
Inbox
registered user.
