How to read IFR
How to read IFR
zhaoqinsu
PE in the preparation of samples before, will read IFR; then read the UIFR or TIFR? After reading the results, how can I judge if the results are correct?
xiangjun_rong
Hi, Su,
can you tell us the part number you are using? what is UIFR and TIFR? do you mean that the IFR is the IFR defined in on-chip Flash for Kinetis family?
Xiangjun Rong
zhaoqinsu
S32K148 .I want read UIFR and TIFR ,but the result is "00" when use the method as S32K144.
xiangjun_rong
Hi, Su,
I am sorry, this is Kinstis SDK community, I am not familiar with the S32 family. Pls create a ticket in S32 community.
Xiangjun Rong
zhaoqinsu
 It does not matter. Thank you for you concerned about my question.
