Will integrated flash programmer work after 30 days evaluation period?
umasankarkallur
Hi ,
I was wondering I can use the integrated flash programmer only after 30 days evaluation period.
I am not using the code warrior for any compilation or debugging but just for flash programming.
-Umasankar K
stanish
could you please indicate which CodeWarrior version you are using?
Stan
umasankarkallur
I am using Code warrior 10.7 versions
-Umasankar K
stanish
Yes, Integrated Flash Programmer should work fine even if your evaluation period expires (it switches to Free - Special Edition version).
Stan
