Has anyone managed to use KSDK CDC Example with Windows WriteFile?
ashesman
I have tried to use WriteFile to send a short string of eight characters from a Delphi program and c#.  Both of them lockup and writefile never returns .  However, using a terminal program (realterm), it works perfectly!
A breakpoint on the CDC callback is never hit when writefile is called.  However, it is hit many times when the port is opened!
Has anyone managed to use the KSDK CDC with a windows program that uses WriteFile?  Specifically I am using the Composite CDC and MSC example on K24.
HEEELLLLPPPP!!!!!!!!!
Ashley
PitOn
#region CDC Support
public class UsbDeviceMonitor
private ManagementEventWatcher plugInWatcher;
private ManagementEventWatcher unPlugWatcher;
private const string MyDeviceDescription = @"My Device Description";
~UsbDeviceMonitor()
Dispose();
public void Dispose()
if (plugInWatcher != null)
try
plugInWatcher.Dispose();
plugInWatcher = null;
catch (Exception) { }
if (unPlugWatcher == null) return;
try {
unPlugWatcher.Dispose();
unPlugWatcher = null;
public void Start()
const string plugInSql = "SELECT * FROM __InstanceCreationEvent WITHIN 1 WHERE TargetInstance ISA 'Win32_PnPEntity'";
const string unpluggedSql = "SELECT * FROM __InstanceDeletionEvent WITHIN 1 WHERE TargetInstance ISA 'Win32_PnPEntity'";
var scope = new ManagementScope("root\\CIMV2") { Options = { EnablePrivileges = true } };
var pluggedInQuery = new WqlEventQuery(plugInSql);
plugInWatcher = new ManagementEventWatcher(scope, pluggedInQuery);
plugInWatcher.EventArrived += HandlePluggedInEvent;
plugInWatcher.Start();
var unPluggedQuery = new WqlEventQuery(unpluggedSql);
unPlugWatcher = new ManagementEventWatcher(scope, unPluggedQuery);
unPlugWatcher.EventArrived += HandleUnPluggedEvent;
unPlugWatcher.Start();
private void HandleUnPluggedEvent(object sender, EventArrivedEventArgs e)
var description = GetDeviceDescription(e.NewEvent);
foreach (COMPortInfo comPort in COMPortInfo.GetCOMPortsInfo())
// comboBoxPort.Items.Add(string.Format("{0} – {1}", comPort.Name, comPort.Description));
// this.comboBoxPort.Items.Add(string.Format("{0}", comPort.Description));
if (description.Equals(MyDeviceDescription)) {
// Take actions here when the device is unplugged
private void HandlePluggedInEvent(object sender, EventArrivedEventArgs e)
if (description.Equals(MyDeviceDescription)){
// Take actions here when the device is plugged in
private static string GetDeviceDescription(ManagementBaseObject newEvent)
var targetInstanceData = newEvent.Properties["TargetInstance"];
var targetInstanceObject = (ManagementBaseObject)targetInstanceData.Value;
if (targetInstanceObject == null) return "";
var description = targetInstanceObject.Properties["Description"].Value.ToString();
return description;
internal class ProcessConnection
public static ConnectionOptions ProcessConnectionOptions()
ConnectionOptions options = new ConnectionOptions();
options.Impersonation = ImpersonationLevel.Impersonate;
options.Authentication = AuthenticationLevel.Default;
options.EnablePrivileges = true;
return options;
public static ManagementScope ConnectionScope(string machineName, ConnectionOptions options, string path)
ManagementScope connectScope = new ManagementScope();
connectScope.Path = new ManagementPath(@"\\" + machineName + path);
connectScope.Options = options;
connectScope.Connect();
return connectScope;
public class COMPortInfo
public string Name { get; set; }
public string Description { get; set; }
public COMPortInfo() { }
public static List<COMPortInfo> GetCOMPortsInfo()
List<COMPortInfo> comPortInfoList = new List<COMPortInfo>();
ConnectionOptions options = ProcessConnection.ProcessConnectionOptions();
ManagementScope connectionScope = ProcessConnection.ConnectionScope(Environment.MachineName, options, @"\root\CIMV2");
ObjectQuery objectQuery = new ObjectQuery("SELECT * FROM Win32_PnPEntity WHERE ConfigManagerErrorCode = 0");
ManagementObjectSearcher comPortSearcher = new ManagementObjectSearcher(connectionScope, objectQuery);
using (comPortSearcher)
string caption = null;
foreach (ManagementObject obj in comPortSearcher.Get())
if (obj != null)
object captionObj = obj["Caption"];
if (captionObj != null)
caption = captionObj.ToString();
if (caption.Contains("(COM"))
COMPortInfo comPortInfo = new COMPortInfo();
comPortInfo.Name = caption.Substring(caption.LastIndexOf("(COM")).Replace("(", string.Empty).Replace(")",
string.Empty);
comPortInfo.Description = caption;
comPortInfoList.Add(comPortInfo);
return comPortInfoList;
* Base Class
public class MySerialPort : SerialPort
private const int DataSize = 256; //
private readonly byte[] _bufer = new byte[DataSize];
private int _stepIndex = 0;
/// </summary>
public MySerialPort()
: base()
// Set parameter
base.BaudRate = 115200;
base.DataBits = 8;
base.StopBits = StopBits.One;
base.Parity = Parity.None;
base.ReadTimeout = 1000;
base.DtrEnable = true;
_stepIndex = 0;
if (base.IsOpen)
base.Close();
// Event Data Received;
base.DataReceived += SerialPort_DataReceived;
// Event Error
base.ErrorReceived += SerialPort_ErrorReceived;
void SerialPort_ErrorReceived(object sender, SerialErrorReceivedEventArgs e)
// if(e.EventType == SerialError.TXFull).....
MessageBox.Show("Error recieved: " + e.EventType);
// Open Port "com1"
public void Open(string portName)
try
if (base.IsOpen)
base.Close();
base.PortName = portName;
base.Open();
base.DiscardInBuffer();
_stepIndex = 0;
catch { }
_stepIndex = 0;
//------> Out Data <-------
public void Send_CmdData(byte[] buffer)
byte CS = 0;
try
for (byte i = 0; i < buffer[1] - 1; i++)
CS += buffer[i];
buffer[buffer[1] - 1] = (byte)(~CS + 1);
base.Write(buffer, 0, buffer[1]);
catch { }
// --Test Input Data
void SerialPort_DataReceived(object sender, SerialDataReceivedEventArgs e)
var port = (SerialPort)sender;
try
int buferSize = port.BytesToRead;
for (int i = 0; i < buferSize; ++i)
_bufer[_stepIndex++] = (byte)port.ReadByte();
if (_stepIndex == 1)
if (0x05 != _bufer[0]) _stepIndex = 0;
else continue;
else
if ((_stepIndex >= DataSize) || (_stepIndex == _bufer[1]))
byte CS = 0;
for (int j = 0; _stepIndex != 0; _stepIndex--)
CS += _bufer[j++];
if (CS == 0)
_stepIndex = 0; // ..
Egor_Host.Egor.CallBackMy.callbackEventHandler(_bufer);
// Egor_Host.FreqStripStatus.Text += "+";
catch { }
#endregion
ashesman
Thanks for that.  Is this code you have successfully used with the SDKD CDC?
PitOn
ashesman
OK.  thanks, will give it a go.  Note that the last person that posted in the forum you mention has the same problem I am having!
