NVT4857UK, DAT3B pull-down
Question asked by Adam Orosz on Feb 11, 2017
Latest reply on Feb 13, 2017 by Tomas Vaverka
Hey there,
I am working on a project that utilizes the NVT4857UK level translator. The functional diagram (on page 4 of the datasheet) indicates that the DAT3B pin is pulled down to the ground directly, without a resistor. I assume that there should be a resistor between the DAT3B line and the ground, otherwise the pin would be logical 0 all the time. I was wondering if this assumption was correct, or if I was missing an important detail.
Kind regards,
Adam Orosz
Link to the datasheet: http://www.nxp.com/documents/data_sheet/NVT4857UK.pdf
