How to increase system.img larger than 512MB ?
david5icp
I had refer Fastboot to flash file size bigger than 512MB  to modify "SYSTEM_ROM_SIZE" large than 512MB, after that I can download system.img via MFG tool. But I can't boot normally. The logs as attached file. It seems  can't access /system partition. How to change system.img larger than 512MB correctly ?
Thanks.
David.
Original Attachment has been moved to: system-1gb-boot.txt.zip
Labels (3)
david5icp
Hi All,
 Some mistakes on mksdcard-android.sh on my side. It's working now..
