Accelerometer for a remote controller
dmitryvasilenko
Hi, which accelerometer is the most successful for a remote control system (e.g. gamin system)? Note the application is cost sensitive.
dmitryvasilenko
Hi, Anthony, thank you for asking. We need a solution that simply says that a smart speaker in upright or horisontal positions. There is no need to check an orientation, just 2 positions. There is no spec for reactivity.
anthonyduhamel
Hi Dimitry,
Thanks for writing to us. Can you develop a little bit more on what you want to do with your remote control?  We need to know what's the main purpose (do you want to detect an orientation?, how should be the reactivity?......) , and check which product can fit with. Then we would be able to help you.
Thank you,
Anthony
dmitryvasilenko
