I'm trying to test a QT example to display a web page. I use the examples "quicknanobrowser" or "minimal" (QML version). I am with an IMX6DL on a yocto 2.0 and QT5.5.1 provided by Technexion. For my future needs I create a Yocto distribution without X11 and Wayland.
When I launch the examples with option "-platform egls" (build with the correct toolchain (meta-toolchain-qt5)) there is no crash, the interface is correctly display but the web page isn't load (I have a functional internet connection)
Can you help me?
Cordially.
Y.DURAND
Hi yd,
You can try the Buffer tests to send file trough Ethernet in order to check your Ethernet image connection. Those unit test are mentioned in the Linux reference manual sect 6.4.1 documentation.
