Using Multi Setup Scripts (*.mbs)
jm1015
We are using P1015 processor for developing an application using MULTI IDE.
Please clarify regarding usage of Multi Setup Scripts (*.mbs) files.
a. Is it necessary to edit the default *.mbs files generated when application is created?
b. Assuming there are additional hardware peripherals eg. DDR, PCI, NVRAM etc , should there be any kind of addition/modification to be done in *.mbs files? or the required hardware initialization in main() is sufficient to use those peripherals?
