MKL02Z32CAF4R
MKL02Z32CAF4R
sebastianmartiu
I have two questions about the Kinetis MKL02Z32CAF4R:
Is the Kinetis MKL02Z32CAF4R with the WLCSP case (Pitch 0.4mm) still in production?
Could I use the Kinetis MKL02Z32CAF4R without a external XTAL crystal?
Robin_Shen
The Kinetis MKL02Z32CAF4R with the WLCSP case (Pitch 0.4mm) still in production(Active).
Yes. You can use internal reference clock.
Robin
Robin_Shen
Robin
sebastianmartiu
Thank you Shen :-)
