I'm having trouble with OND to a JN5168 module
mariocosta
I tried doing an OND on a JN5168 module and the connection was lost. Now the module is stuck on programming mode (2). Is there a way to clear  programming status in the Image?
thanks
Mario
mario_castaneda
Hi Mario,
You can take a look the next Note.
10.8.3 Performing a Download
http://www.nxp.com/documents/user_manual/JN-UG-3080.pdf?fsrch=1&sr=1&pageNum=1
Reading any variable of the OND MIB, except Images, will reset the values of DeviceID, ChipSet and Revision to those of the application image that is currently running on the node.
Mario
