ADC pin configuration of i.MX6 UL
vineethhegde
The ten analog input pin of i.MX6UL is shared with two ADC's ie ADC1 and ADC2.
When am using multiple analog input from multiple devices whether same data will go to both the ADC's ? So at that time how to differentiate the data from different ADC devices.
 Please clasrify.
Vineeth
jamesbone
Hello Vineeth,
Let me clarify that you only have one ADC module,  which has  2 different options, you can choose ADC1 or ADC2 instance, but at the end you only have 10 channels connected to only  One ADC module.
Hope this clarifies.
Jaime Hueso
