For using an Explore NFC Board with Raspberry Pi 3 should we have to install separate device drivers apart from the existing ones? And Will it support libnfc?
akshaykumarsr
Will it also come with NeardAL inbuilt in it?
Kan_Li
Hi Akshay Kumar S R,
If you start with the Raspbian “Jessie” image from the download page of the Raspberry Pi foundation , you have to install packages before going ahead, you may get all the packages from EXPLORE-NFC - Exclusive from element14|NXP , please kindly refer to http://www.nxp.com/documents/application_note/AN11480.pdf  for more details.
Hope that helps,
Kan
akshaykumarsr
Thanks for the information Kan_Li.
