Setting fb other than fb0 as a primary
Question asked by Ambika . on Feb 6, 2017
Latest reply on Feb 15, 2017 by Ambika .
Hii,
I'm working on imx6q processor with yocto dizzy(linux kernel 3.14).
Currently the data is writing to /dev/fb0 and from there to my primary display through the first LVDS channel  (LVDS0).
ldb node in dtsi is as below,
&ldb {
status = "okay";
lvds-channel@0 {
fsl,data-mapping = "spwg";
fsl,data-width = <18>;
primary;
crtc = "ipu1-di0";
status = "okay";
display-timings {
native-mode = <&timing0>;
timing0: ldb-wvga {
clock-frequency = <33260000>;
hactive = <800>;
vactive = <480>;
hback-porch = <88>;
hfront-porch = <40>;
vback-porch = <33>;
vfront-porch = <10>;
hsync-len = <128>;
vsync-len = <2>;
From u-boot mxcfb0 tis set to primary display
I assume that currently the data write will be to ipu1_di0 i.e /dev/fb0 and that fb0 is configured to display.
I want to achieve the following,
  1. Write the data to other than ipu1_di0 (if possible to virtual frame buffer) say to fbx.
  2. From fbx to fb0 (on doing some operations like scaling on data in fbx to fb0)
Configuration /dev/fb0 to display is okey.
Please let know the procedure to achieve (1)
Thanks in advance.
Ambika
