MKW30Z new PCB sw set-up
Question asked by Lucian Firan on Feb 5, 2017
KW40Z_Connectivity_Software_1.0.1 (KSDK_1.3.0) IAR 7.50
If new PCB is used; mitigate from MKW40Z to MKW30Z chip
- DCDC bypass mode used
- no low power mode used
- no HW RTC used
- no GPIO led or keyboard used
- output 5 TPM PWM outs to transistors
- input 1 TSI from touch button
- no ext ADC only core temp ADC used
How to modify these files is there an automate tool ?
and app_preinclude.h
New PCB pinouts:
/* MKW30Z new PCB pinout
32QFN,PinName,DEFAULT  , PCB function, used
 1,PTC19     ,DISABLED , SPI0_PCS0   , yes to AT45DB021E-SSHN-T  +10K pullup
 2,PTA0      ,SWD_DIO  , TPM1_CH0    , yes in debug SWD_DIO
 3,PTA1      ,SWD_CLK  , SWD_CLK     , yes in debug SWD_CLK
 4,PTA2      ,RESET_b  , RESET_b     , yes
 5,PSWITCH   ,PSWITCH  , PSWITCH     , yes tied to GND
 6,DCDC_CFG  ,DCDC_CFG , DCDC_CFG    , yes tied to 3.3V
 7,VDCDC_IN  ,VDCDC_IN , VDCDC_IN    , yes tied to 3.3V
 8,DCDC_GND  ,DCDC_GND , DCDC_GND    , yes tied to GND
 9,DCDC_LP   ,DCDC_LP  , DCDC_LP     , open
10,DCDC_LN   ,DCDC_LN  , DCDC_LN     , open
11,VDD_1P8OUT   ,VDD_1P8OUT ,VDD_1P8OUT ,yes tied to 3.3V
12,VDD_1P45OUT_PMCIN,VDD_1P45OUT_PMCIN,VDD_1P45OUT_PMCIN, yes tied to 3.3V
13,PTB3      ,ADC0_SE2/CMP0_IN4,TPM1_CH1, yes  Leds channel BSS205
14,VDD_0     ,—        ,—            , yes tied to 3.3V
15,PTB16     ,EXTAL32K ,             , open
16,PTB17     ,XTAL32K  ,             , open
17,PTB18     ,NMI_b    ,TPM0_CH0     , yes Leds channel BSS205
18,VDDA      ,VDDA     ,VDDA         , yes tied to 3.3V
19,EXTAL_32M ,EXTAL_32M,EXTAL_32M    , yes to NXS3225SA-EXS00A-CS02368
20,XTAL_32M  ,XTAL_32M ,XTAL_32M     , yes to NXS3225SA-EXS00A-CS02368
21,VDD_RF2   ,VDD_RF2  ,VDD_RF2      , yes tied to 3.3V
22,RF_N      ,RF_N     ,RF_N         , yes to MURATA-LDB212G4005C-001
23,RF_P      ,RF_P     ,RF_P         , yes to MURATA-LDB212G4005C-001
24,VDD_RF1   ,VDD_RF1  ,VDD_RF1      , yes tied to 3.3V
25,PTC0      ,DISABLED ,TPM0_CH1     , yes Leds channel BSS205
26,PTC1      ,DISABLED ,TPM0_CH2     , yes Leds channel BSS205
27,PTC2      ,DISABLED ,             , open
28,PTC3      ,DISABLED ,TSI0_CH15    , yes capacitive touch sensor
29,VDD_1     ,VDD      ,—            , yes tied to 3.3V
30,PTC16     ,DISABLED ,SPI0_SCK     , yes to AT45DB021E-SSHN-T  +10K pullup
31,PTC17     ,DISABLED ,SPI0_SOUT    , yes to AT45DB021E-SSHN-T  +10K pullup
32,PTC18     ,DISABLED ,SPI0_SIN     , yes to AT45DB021E-SSHN-T
33-41,Ground ,NA       ,GND          , yes tied to GND
Reference manual pinout:
/* MKW40Z MKW30Z pinout
48QFN,32QFN,PinName,DEFAULT    ,ALT0     ,ALT1 ,ALT2 ,ALT3 ,ALT4 ,ALT5 ,ALT6 ,ALT7
 1, 2,PTA0         ,SWD_DIO    ,TSI0_CH8 ,PTA0 ,SPI0_PCS1,— ,— ,TPM1_CH0,— ,SWD_DIO
 2, 3,PTA1         ,SWD_CLK    ,TSI0_CH9 ,PTA1 ,— ,— ,— ,TPM1_CH1,— ,SWD_CLK
 3, 4,PTA2         ,RESET_b    ,— ,PTA2 ,— ,— ,— ,TMP0_CH3,— ,RESET_b
 4, —,PTA16        ,DISABLED   ,TSI0_CH10 ,PTA16/LLWU_P4,SPI1_SOUT,— ,— ,TPM0_CH0,— ,—
 5, —,PTA17        ,DISABLED   ,TSI0_CH11 ,PTA17/LLWU_P5,SPI1_SIN,— ,— ,TPM_CLKIN1,— ,—
 6, —,PTA18        ,DISABLED   ,TSI0_CH12 ,PTA18/LLWU_P6,SPI1_SCK,— ,— ,TPM2_CH0,— ,—
 7, —,PTA19        ,DISABLED   ,TSI0_CH13 ,PTA19/LLWU_P7,SPI1_PCS0,— ,— ,TPM2_CH1,— ,—
 8, 5,PSWITCH      ,PSWITCH    ,PSWITCH ,— ,— ,— ,— ,— ,— ,—
 9, 6,DCDC_CFG     ,DCDC_CFG   ,DCDC_CFG ,— ,— ,— ,— ,— ,— ,—
10, 7,VDCDC_IN     ,VDCDC_IN   ,VDCDC_IN ,— ,— ,— ,— ,— ,— ,—
11, 9,DCDC_LP      ,DCDC_LP    ,DCDC_LP ,— ,— ,— ,— ,— ,— ,—
13, 8,DCDC_GND     ,DCDC_GND   ,DCDC_GND ,— ,— ,— ,— ,— ,— ,—
14,11,VDD_1P8OUT   ,VDD_1P8OUT ,VDD_1P8OUT ,— ,— ,— ,— ,— ,— ,—
12,10,DCDC_LN      ,DCDC_LN    ,DCDC_LN ,— ,— ,— ,— ,— ,— ,—
15,12,VDD_1P45OUT_PMCIN,VDD_1P45OUT_PMCIN,VDD_1P45OUT_PMCIN,— ,— ,— ,— ,— ,— ,—
16, —,PTB0         ,DISABLED   ,— ,PTB0/LLWU_P8,— ,I2C0_SCL,CMP0_OUT,TPM0_CH1,— ,CLKOUT
17, —,PTB1         ,ADC0_SE1/CMP0_IN5,ADC0_SE1/CMP0_IN5,PTB1 ,— ,I2C0_SDA,LPTMR0_ALT1,TPM0_CH2,— ,CMT_IRO
18, —,PTB2         ,ADC0_SE3/CMP0_IN3,ADC0_SE3/CMP0_IN3,PTB2 ,— ,— ,— ,TPM1_CH0,— ,—
19,13,PTB3         ,ADC0_SE2/CMP0_IN4,ADC0_SE2/CMP0_IN4,PTB3 ,— ,— ,CLKOUT,TPM1_CH1,— ,RTC_CLKOUT
20,14,VDD_0        ,—        ,—        ,— ,— ,— ,— ,— ,— ,—
21,15,PTB16        ,EXTAL32K ,EXTAL32K ,PTB16 ,— ,I2C1_SCL,— ,TPM2_CH0,— ,—
22,16,PTB17        ,XTAL32K  ,XTAL32K ,PTB17 ,— ,I2C1_SDA,— ,TPM2_CH1,— ,—
23,17,PTB18        ,NMI_b ,DAC0_OUT/ADC0_SE4/CMP0_IN2,PTB18 ,— ,I2C1_SCL,TPM_CLKIN0,TPM0_CH0,— ,NMI_b
24,— ,ADC0_DP0     ,ADC0_DP0/CMP0_IN0,ADC0_DP0/CMP0_IN0,— ,— ,— ,— ,— ,— ,—
25,— ,ADC0_DM0     ,—        ,ADC0_DM0/CMP0_IN1,— ,— ,— ,— ,— ,— ,—
26,— ,VSSA         ,VSSA     ,VSSA ,— ,— ,— ,— ,— ,— ,—
27,— ,VREFH        ,VREFH    ,VREFH ,— ,— ,— ,— ,— ,— ,—
28,18,VDDA         ,VDDA     ,VDDA ,— ,— ,— ,— ,— ,— ,—
29,19,EXTAL_32M    ,EXTAL_32M,EXTAL_32M ,— ,— ,— ,— ,— ,— ,—
30,20,XTAL_32M     ,XTAL_32M ,XTAL_32M ,— ,— ,— ,— ,— ,— ,—
31,— ,VDD_XTAL     ,VDD_XTAL ,VDD_XTAL ,— ,— ,— ,— ,— ,— ,—
32,21,VDD_RF2      ,VDD_RF2  ,VDD_RF2 ,— ,— ,— ,— ,— ,— ,—
33,22,RF_N         ,RF_N     ,RF_N ,— ,— ,— ,— ,— ,— ,—
34,23,RF_P         ,RF_P     ,RF_P ,— ,— ,— ,— ,— ,— ,—
35,24,VDD_RF1      ,VDD_RF1  ,VDD_RF1   ,— ,— ,— ,— ,— ,— ,—
36,25,PTC0         ,DISABLED ,—         ,PTC0/LLWU_P9,ANT_A ,I2C0_SCL,UART0_CTS_b,TPM0_CH1,— ,—
37,26,PTC1         ,DISABLED ,—         ,PTC1 ,ANT_B ,I2C0_SDA,UART0_RTS_b,TPM0_CH2,— ,BLE_ACTIVE
38,27,PTC2         ,DISABLED ,TSI0_CH14 ,PTC2/LLWU_P10,TX_SWITCH,I2C1_SCL,UART0_RX,CMT_IRO,— ,DTM_RX
39,28,PTC3         ,DISABLED ,TSI0_CH15 ,PTC3/LLWU_P11,RX_SWITCH,I2C1_SDA,UART0_TX,— ,— ,DTM_TX
40,— ,PTC4         ,DISABLED ,TSI0_CH0  ,PTC4/LLWU_P12,— ,EXTRG_IN,UART0_CTS_b,TPM1_CH0,— ,—
41,— ,PTC5         ,DISABLED ,TSI0_CH1  ,PTC5/LLWU_P13,— ,LPTMR0_ALT2,UART0_RTS_b,TPM1_CH1,— ,—
42,— ,PTC6         ,DISABLED ,TSI0_CH2  ,PTC6/LLWU_P14,— ,I2C1_SCL,UART0_RX,TPM2_CH0,— ,—
43,— ,PTC7         ,DISABLED ,TSI0_CH3  ,PTC7/LLWU_P15,SPI0_PCS2,I2C1_SDA,UART0_TX,TPM2_CH1,— ,—
44,29,VDD_1        ,VDD       ,—        ,— ,— ,— ,— ,— ,— ,—
45,30,PTC16        ,DISABLED ,TSI0_CH4  ,PTC16/LLWU_P0,SPI0_SCK,I2C0_SDA,UART0_RTS_b,TPM0_CH3,— ,—
46,31,PTC17        ,DISABLED ,TSI0_CH5  ,PTC17/LLWU_P1,SPI0_SOUT,— ,UART0_RX,— ,— ,DTM_RX
47,32,PTC18        ,DISABLED ,TSI0_CH6  ,PTC18/LLWU_P2,SPI0_SIN,— ,UART0_TX,— ,— ,DTM_TX
48, 1,PTC19        ,DISABLED ,TSI0_CH7  ,PTC19/LLWU_P3,SPI0_PCS0,I2C0_SCL,UART0_CTS_b,— ,— ,BLE_ACTIVE
49-64,33-41        ,Ground   ,NA        ,NA ,NA ,NA ,NA ,NA ,NA ,NA ,NA
Lucian
