IMX6Q ADDING PHP PACKAGES IN YOCTO(NEED HELP)
mustafabakircio
Hello guys ;
I have been working on the webserver application about 1 week , in my project I need to add php packages and php features to y image in yocto but I coundnt  make it  , I m finding  the php packages with
fsl-community-bsp/build :  bitbake -e php | grep "^PACKAGES="
 the result is
PACKAGE: php-cli php-dev php-apache2- ......  and etc .
When I put these packages to the local.conf like IMAGE_INSTALL_append = " php-cli php-fpm php-dev ..."
I get a build error   which is :
ERROR: php-staticdev not found in the base feeds (wandboard_quad cortexa9hf-vfp-neon-mx6qdl cortexa9hf-vfp-neon cortexa9hf-vfp armv7ahf-vfp-neon armv7ahf-vfp armv6hf-vfp armv5ehf-vfp armv5hf-vfp noarch any all).
acl-2.2.52-r0@cortexa9hf_vfp_neon acl-dbg-2.2.52-r0@cortexa9hf_vfp_neon acl-dev-2.2.52-r0@cortexa9hf_vfp_neon acl-doc-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-de-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-es-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-fr-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-gl-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-pl-2.2.52-r0@cortexa9hf_vfp_neon acl-locale-sv-2.2.52-r0@cortexa9hf_vfp_neon acl-ptest-2.2.52-r0@cortexa9hf_vfp_neon alsa-conf-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-conf-base-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-lib-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-lib-dbg-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-lib-dev-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-server-1.0.28-r0@cortexa9hf_vfp_neon_mx6qdl alsa-state-0.2.0-r5@wandboard_quad alsa-state-dbg-0.2.0-r5@wandboard_quad alsa-state-dev-0.2.0-r5@wandboard_quad alsa-states-0.2.0-r5@wandboard_quad alsa-utils-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-aconnect-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-alsactl-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-alsaloop-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-alsamixer-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-alsaucm-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-amixer-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-aplay-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-aseqdump-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-aseqnet-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-dbg-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-dev-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-doc-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-iecset-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-locale-de-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-locale-fr-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-locale-ja-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-locale-ru-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-midi-1.0.28-r0@cortexa9hf_vfp_neon alsa-utils-speakertest-1.0.28-r0@cortexa9hf_vfp_neon apache2-2.4.10-r0@cortexa9hf_vfp_neon apache2-dbg-2.4.10-r0@cortexa9hf_vfp_neon apache2-dev-2.4.10-r0@cortexa9hf_vfp_neon apache2-doc-2.4.10-r0@cortexa9hf_vfp_neon apache2-scripts-2.4.10-r0@cortexa9hf_vfp_neon apm-3.2.2+14-r2@cortexa9hf_vfp_neon apmd-3.2.2+14-r2@cortexa9hf_vfp_neon apmd-dbg-3.2.2+14-r2@cortexa9hf_vfp_neon apmd-dev-3.2.2+14-r2@cortexa9hf_vfp_neon atftp-0.7.1+git0+be3291a18c-r3@cortexa9hf_vfp_neon atftp-dbg-0.7.1+git0+be3291a18c-r3@cortexa9hf_vfp_neon atftp-dev-0.7.1+git0+be3291a18c-r3@cortexa9hf_vfp_neon atftp-doc-0.7.1+git0+be3291a18c-r3@cortexa9hf_vfp_neon atftpd-0.7.1+git0+be3291a18c-r3@cortexa9hf_vfp_neon attr-2.4.47-r0@cortexa9hf_vfp_neon attr-dbg-2.4.47-r0@cortexa9hf_vfp_neon attr-dev-2.4.47-r0@cortexa9hf_vfp_neon attr-doc-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-cs-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-de-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-es-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-fr-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-gl-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-nl-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-pl-2.4.47-r0@cortexa9hf_vfp_neon attr-locale-sv-2.4.47-r0@cortexa9hf_vfp_neon attr-ptest-2.4.47-r0@cortexa9hf_vfp_neon autoconf-2.69-r11@cortexa9hf_vfp_neon autoconf-dbg-2.69-r11@cortexa9hf_vfp_neon autoconf-dev-2.69-r11@cortexa9hf_vfp_neon autoconf-doc-2.69-r11@cortexa9hf_vfp_neon automake-1.14.1-r0@cortexa9hf_vfp_neon automake-dbg-1.14.1-r0@cortexa9hf_vfp_neon automake-dev-1.14.1-r0@cortexa9hf_vfp_neon automake-doc-1.14.1-r0@cortexa9hf_vfp_neon avahi-autoipd-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-daemon-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-dbg-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-dev-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-dnsconfd-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-doc-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-bg-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-ca-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-cs-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-da-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-de-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-el-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-en-au-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-en-ca-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-en-gb-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-en-nz-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-es-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-fi-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-fo-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-fr-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-gl-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-he-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-hu-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-id-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-it-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-ja-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-ms-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-nl-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-pl-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-pt-br-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-ro-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-ru-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-sl-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-sr-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-sr+latin-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-sv-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-uk-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-zh-cn-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-locale-zh-tw-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-staticdev-0.6.31-r11.1@cortexa9hf_vfp_neon avahi-utils-0.6.31-r11.1@cortexa9hf_vfp_neon base-files-3.0.14-r89@wandboard_quad base-files-dbg-3.0.14-r89@wandboard_quad base-files-dev-3.0.14-r89@wandboard_quad base-files-doc-3.0.14-r89@wandboard_quad base-passwd-3.5.29-r0@cortexa9hf_vfp_neon base-passwd-dbg-3.5.29-r0@cortexa9hf_vfp_neon base-passwd-dev-3.5.29-r0@cortexa9hf_vfp_neon base-passwd-doc-3.5.29-r0@cortexa9hf_vfp_neon base-passwd-update-3.5.29-r0@cortexa9hf_vfp_neon bash-4.3-r0@cortexa9hf_vfp_neon bash-dbg-4.3-r0@cortexa9hf_vfp_neon bash-dev-4.3-r0@cortexa9hf_vfp_neon bash-doc-4.3-r0@cortexa9hf_vfp_neon bash-ptest-4.3-r0@cortexa9hf_vfp_neon bc-1.06-r2@cortexa9hf_vfp_neon bc-dbg-1.06-r2@cortexa9hf_vfp_neon bc-dev-1.06-r2@cortexa9hf_vfp_neon bc-doc-1.06-r2@cortexa9hf_vfp_neon bcm4329-nvram-config-1.0-r0@wandboard_quad bcm4329-nvram-config-dbg-1.0-r0@wandboard_quad bcm4329-nvram-config-dev-1.0-r0@wandboard_quad bcm4330-nvram-config-1.0-r0@wandboard_quad bcm4330-nvram-config-dbg-1.0-r0@wandboard_quad bcm4330-nvram-config-dev-1.0-r0@wandboard_quad binutils-2.24-r0@cortexa9hf_vfp_neon binutils-dbg-2.24-r0@cortexa9hf_vfp_neon binutils-dev-2.24-r0@cortexa9hf_vfp_neon binutils-doc-2.24-r0@cortexa9hf_vfp_neon binutils-locale-bg-2.24-r0@cortexa9hf_vfp_neon binutils-locale-da-2.24-r0@cortexa9hf_vfp_neon binutils-locale-de-2.24-r0@cortexa9hf_vfp_neon binutils-locale-eo-2.24-r0@cortexa9hf_vfp_neon binutils-locale-es-2.24-r0@cortexa9hf_vfp_neon binutils-locale-fi-2.24-r0@cortexa9hf_vfp_neon binutils-locale-fr-2.24-r0@cortexa9hf_vfp_neon binutils-locale-ga-2.24-r0@cortexa9hf_vfp_neon binutils-locale-hr-2.24-r0@cortexa9hf_vfp_neon binutils-locale-id-2.24-r0@cortexa9hf_vfp_neon binutils-locale-it-2.24-r0@cortexa9hf_vfp_neon binutils-locale-ja-2.24-r0@cortexa9hf_vfp_neon binutils-locale-ms-2.24-r0@cortexa9hf_vfp_neon binutils-locale-nl-2.24-r0@cortexa9hf_vfp_neon binutils-locale-pt-br-2.24-r0@cortexa9hf_vfp_neon binutils-locale-ro-2.24-r0@cortexa9hf_vfp_neon binutils-locale-ru-2.24-r0@cortexa9hf_vfp_neon binutils-locale-rw-2.24-r0@cortexa9hf_vfp_neon binutils-locale-sk-2.24-r0@cortexa9hf_vfp_neon binutils-locale-sr-2.24-r0@cortexa9hf_vfp_neon binutils-locale-sv-2.24-r0@cortexa9hf_vfp_neon binutils-locale-tr-2.24-r0@cortexa9hf_vfp_neon binutils-locale-uk-2.24-r0@cortexa9hf_vfp_neon binutils-locale-vi-2.24-r0@cortexa9hf_vfp_neon binutils-locale-zh-cn-2.24-r0@cortexa9hf_vfp_neon binutils-locale-zh-tw-2.24-r0@cortexa9hf_vfp_neon binutils-staticdev-2.24-r0@cortexa9hf_vfp_neon bison-2.7.1-r0@cortexa9hf_vfp_neon bison-dbg-2.7.1-r0@cortexa9hf_vfp_neon bison-dev-2.7.1-r0@cortexa9hf_vfp_neon bison-doc-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ast-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-da-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-de-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-el-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-eo-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-es-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-et-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-fi-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-fr-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ga-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-gl-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-hr-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-hu-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-id-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-it-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ja-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ky-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-lt-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-lv-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ms-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-nb-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-nl-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-pl-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-pt-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-pt-br-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ro-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-ru-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-sl-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-sq-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-sr-2.7.1-r0@cortexa9hf_vfp_neon bison-locale-sv-2.7.1-........
I'm using dizzy branch and my kernel version is 3.10.17
I need to solve this issue but I ' m getting hopeless about it . Do you have any suggestion or do I missing something ?
I  stuck on this .
jimmychan
The error is " php-staticdev not found", so how about this ?
bitbake -e php | grep ^FILES_
mustafabakircio
Thank for your reply jimmychan
Yes I tried it and the result  is ;
FILES_php-doc="/usr/share/doc /usr/share/man /usr/share/info /usr/share/gtk-doc /usr/share/gnome/help /usr/lib/php5/php/doc"
FILES_php-cgi="/usr/bin/php-cgi"
FILES_php-locale="/usr/share/locale"
FILES=""
FILES_php-dbg="/usr/bin/.debug /usr/lib/apache2/modules/.debug /usr/lib/debug /usr/src/debug"
FILES_php-fpm-apache2="/etc/apache2/conf.d/php-fpm.conf"
FILES_php-fpm="/usr/sbin/php-fpm /etc/php-fpm.conf /usr/share/fpm /etc/init.d/php-fpm /lib/systemd/system/php-fpm.service /etc/php-fpm.d/www.conf.default"
Can you help me about how to use these informations about adding to my image?
jimmychan
3.10.17 is quite old. Have you try newer version BSP?
mustafabakircio
Hi jimmychan ;
And yes I  changed the branch and made it master branch , but I still taking the same error
I wonder if master branch not stable at all ?
Thanks ..
