User segment in flash in Kinetis 64 (frdm kinetis)
mikaelelharrar
I'm using freedom dev. board FRDM K64 and would like to define a user segment in my flash in order to store there some application data.
Someone knows how to do that ?
Because the main constraint is to avoid the (future) bootloader and the jtag to not erase this segment.
For your information I'm using kinetis studio.
One important other question:
- What is the minimum size of a flash segment ? I see 4K, but is it possible to write only some bytes only or I need to erase all the block each time I want to write on it ?
Mikael
Tags (2)
