James Bowen
How do i put an array into the Code segment instead of data segment?
Discussion created by James Bowen on Jul 17, 2008
Latest reply on Jul 19, 2008 by James Bowen
Hello Guys,
I have a long array that I is not gonna be changed and I dont want to use an EEPROM or Serial Flash. I remembered that i can do this with Keil C51 using storage modifier "code".  I was wondering if the Codewarrior V6.1 for HCS08 series. Is there any such modifier that i can before the following code?
unsigned char Array_nv_chg[1024] = {...};
Samuel
