Generate .hex file in 32k144
lohrsistemas
I'm using 32k144 Mcu and S32 design studio for ARM, with IAR plugin. When I try generate the .hex file, an error occour (could not open file "config.icf"). Any idea what's happening?
Labels (2)
Tags (2)
stanish
Thanks for the report - I can reproduce the issue.
Seems IAR Plugin doubles the quotation marks the linker configuration file (.icf) path if an additional output file generation is enabled. I'd suggest you to manually delete quotation marks in Linker configuration file edit box as a workaround:
Now the build is successful and there is the binary file generated.
Hope it helps.
Stan
lohrsistemas
Thank you Stan.
That solved my problem.
