Newbie:  fsl-image-gui ...how to get gui on LCD?
Question asked by Carl Schultz on Jan 31, 2017
Latest reply on Feb 2, 2017 by Carl Schultz
I was able to boot imx6ul evk with SD card
The bitbake process went ok (i.e. finished building without any errors)
(kernel used: fsl-arm-yocto-bsp.git -b imx-4.1.15-1.0.0_ga)
(image recipe: fsl-image-gui)
fsl-image-gui-imx6ulevk.sdcard -> fsl-image-gui-imx6ulevk-20170131150543.rootfs.sdcard
I get a linux prompt through serial console.
The attached LCD display also shows a linux login prompt.
I was expecting to see a GUI on the LCD (based on the recipe name).
Should I expect GUI on the LCD?
Or do I have to write an application before building the image?
I will appreciate any guidance to a solution or resource.
Thank you,
Carl
