Looking for MPC8548E local bus IO timing at 2.5V with the PLL bypassed
Question asked by Barry Allred on Jan 31, 2017
Latest reply on Feb 1, 2017 by Serguei Podiatchev
The MPC8548E datasheet doesn't provide local bus IO timing data for BVDD = 2.5V with the PLL disabled.  Separate IO timing is provided for the other three conditions (3.3V/PLL enabled, 3.3V/PLL disabled, 2.5V PLL enabled).  I'm assuming that the IO timing would be different for 2.5V/PLL disabled.  Is that correct?  If so can the IO timing for that use case be provided?
