I am having some trouble at using SPI as Master with DMA transfers enabled in an LPC5410. I couldn't find any good reference code so I'm basing mine on the one in the current version of LPCOpen, which has SPI+DMA though acting as slave.
Does anyone know any reference code I could look at?
Hi Genis,
There is another example of SPI slave with DMA that you can also use as reference, it can be found on the LPCOpen package for the LPCXpresso LPC54102 Sensor Processing/Motion Solution Boards:
LPCOpen Software for LPC5410X|NXP
Hope it helps!
Carlos Mendoza
Technical Support Engineer
