IMX6UL EVK ethernet RMII Mode clock(50MHz) query?
ramesh6663
we are using IMX6UL processor which has support RMII mode. Here my Query is Processor can provide 50Mhz output clock to Ethernet PHY Xtal in pin?
If processor can't provide 50MHz clock O/P to Ethernet PHY, we will go for External Oscillator
Where this mentioned in Datasheet, I tried but i didn't get it. Could you please help us on this?
Thanks & Regards,
Rameshkumar
Hi Rameshkumar
yes processor can provide 50Mhz output clock to Ethernet PHY,
please check IOMUXC_GPR_GPR1 register settings
ENET_TX_CLK_DIR, ENET1_CLK_SEL sect.30.4.2 GPR1 General Purpose
Register (IOMUXC_GPR_GPR1) i.MX6UL Reference Manual
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6ULRM.pdf
