I have a device that is a simple peripheral that will support a few basic profiles. However, I also need this device to receive broadcast advertisements from other devices at the same time. I effectively want it to always pass advertisement packets up to my code regardless of any other state it's in. Can the QN902X do this?
Solved! Go to Solution.
Hi Mike,
While the QN9020 is in the Central role the QN9020 shall support eight connections at the same time. Otherwise, only one.
Mario
NXP has confirmed this functionality does not work.
