Dear Sirs
What is the difference between TJA1040T/CM & TJA1040T/VM, other than the VM is obsolete & the CM is still active?
Best Regards
Rob Coode
Engineering Documentation Manager
For & on behalf of:
Electro Assembly Services Ltd
Unit 5, Lancaster Way
Earls Colne Business Park
Earls Colne
Colchester, Essex CO6 2NS
Tel : 01787 478771 (Ext #204)
Fax: 01787 478772
Email: robc@electroassembly.com<mailto:tim@electroassembly.com>
P Please consider the environment - do you really need to print this email?
Electro Assembly Services Ltd is registered in England No. 03367217.
E-mail Confidentiality Notice and Disclaimer.
This email and any files transmitted with it are confidential and intended solely for those named recipients only. It may be privileged and/or confidential. If you are not the intended named recipient of this email then you should not copy it or use it for any purpose, nor disclose its content to any other person. You should contact Electro Assembly Services Ltd as shown above so that we can take the appropriate action. This email may not represent the views of policy of the company. This email and its attachments have been scanned for known viruses using multiple scanners. however the recipient must take full responsibility for virus checking as Electro Assembly Services Limited accepts no liability for any damage caused by any virus.
Solved! Go to Solution.
Dear Rob,
This IC was moved from our DHAM Fab to our ICN8 Fab, as part of this move the device received a BOM update to bring it in line with our newer products produced in ICN8. There were no changes made to the active area of the die, so there should be no electrical difference between the two versions.
Tomas
Dear Rob,
Tomas
Thanks Tomas, very much appreciated.
Rob Coode
For & on behalf of:
Fax: 01787 478772
