Hello!
How to start with KE04 Kinetis family and KDS? The kexx_drv_lib software package do not contain drivers and examples for KDS and do not Kinetis SDK compatible. I use KDS and KSDK for KL46 family and the best way is use the same tools for KE04.
Thank you for any suggestions.
Hi Leszek Drewniok,
Now, the KE series still don't have the official KDS sample code, it mainly have the IAR, MDK and CW project in kexx_drv_lib .
So, if you want to use the KE04 in the KDS IDE, you need to create the KDS project by yourself, then porting the source code in kexx_drv_lib to the KDS project.
Wish it helps you!
Kerry
