Hello there
I am trying to build an IAR workbench example project given as example in Freescale's KW01 Connectivity software I followed all steps given in the SMAC_Quick_Start_Guide (document attached) as well as tutorial on URL
https://www.iar.com/support/tech-notes/debugger/cmsis-dap---probe-not-found/
but still I am getting the following error as:
Fatal error: Probe not found Session aborted!
It shows some CMSIS-DAP error
please help me out resolving the error
Hi Bhupendra Prajapati
Could you verify that your FRDM list as it should? if you are using Windows, you could go to Device Manager and under Posrts (COM & LPT) list, it should appear as a DAP device. This error could be caused because you try to download your project with CMSIS-DAP inteerface but your device has a Jlink interface. if you interface is not a DAP, please change it in project->option->Debugger->Driver (your driver).
This also could be related with the reset pin, please verify the following link:
FRDM KW40Z "Fatal error:CPU did not power up"
Hope this information helps you
Jorge Alcala
