In my design, 74AVC32T245 is used for SPI signal level shifting.
Some pins do not used and I wonder I should connect unused pin to Vcc or GND. Similar part of TI required unused input should be held at Vcc or GND and unused output can be connected to GND when unused input is held at GND.
I guess unused input can be held at GND, and opposite unused output also can be held at GND, is it correct?
