I have a technical problem. When I compile my project with the software IAR Embedded Workbench I have this error :
"This file should only be compiled in big endian mode" because of the variable __LITTLE_ENDIAN__ == 1 and I go in the loop (file arm7100.h) :
#if __LITTLE_ENDIAN__ == 1
#error This file should only be compiled in big endian mode
#endif
So my question is : Is it possible to change an option in this software for compiling in big endian mode ?
Thank you for your answers.
