K22 flexbus read 16byte issue
hengwu
In burst model, with the edma, k22 read 16bytes from fpga.
The result should be data0+data1...data7. The data is 16bits.
But result is addr+addr+data0+...data5.Addr is also 16bits
So it missed the last data6 and data7.Why?
And i find that the oe signal becomes  high before the data6 appears.
How can i control the oe signal?
