I have the freedom board containing the MK22FN512VLK12 chip set and was told that this board can be used to program the MK22FX512VLK12 chip set. (there are slight differences between the chips how can that be done? Through JTAG I assume. Has anyone done this? I would like to save $200 on a P&E programmer.
using Kenitis IDE v 3.0
thanks!
Solved! Go to Solution.
Hello Jace,
I recommend you refer to this tutorial :
Using the Freescale Freedom (FRDM-KL43Z) to Debug other Boards | MCU on Eclipse
Hope it helps
Alice Yang
Hello Jace,
Hope it helps
Alice Yang
