Problem connection with ethernet port use 3.3V external power supply
Question asked by Juan Olivero on Jan 18, 2017
Latest reply on Jan 21, 2017 by Hui_Ma
Hi.
I need help with the following problem.
I am using an FRDM-K64F powered with an external 3.3V source.
When connecting ethernet port to pc, sometimes does not connect pc with K64F. After restarting the external source several times connect.
I can not find the reason. Can it be bad configuration of the ethernet port of the K64F? Problem in the transient current of the external source?
Thank you. Greetings.
Juan.
