MMA8451Q
MMA8451Q
nadayousif
I am planning to use the MMA8451Q accelerometer in my teaching, but am after more information about the internal dimensions. I assume it is some kind of comb design, but would it be possible to obtain the geometry including dimensions?
david_diaz
Thank you very much for writing.
The MMA8451Q is a 16-pin QFN 3mm x 3mm x 1mm device.
You may find the package information here.
At the links below, you may find useful documentation in regard with the MMA8451Q, besides, you may find example projects.
  1. MMA8451Q documentation
  2. MMA8451Q example projects
Please let me know if you need more material or if you have any further question. We are glad to help.
David
