Is there a way to configure an NXP T1040 to start when power is applied to the box?
Question asked by Jean Harano on Jan 17, 2017
Latest reply on Mar 9, 2017 by Jean Harano
I work in an environment where the development boxes (T1040) are located in a different part of the building.  Occasionally I'll get the box locked up and the only way to recover is to do a physical reset.  We have the T1040 connected to a smart PDU so I can toggle the power remotely but the T1040 still has to be turned on physically by pressing the power switch.  Is there a configuration setting that will make the T1040 power on when power is applied to the box effectively bypassing the need to press the power switch?
