how gstreamer access vpu encoder
anjojohn
i like to know how gst-fsl-plugins access the hardware vpu encode/deimx-vcoder. i can see libfslvpuwrap and imx-vpu as dependencies for gst-fsl plugins. But in latest git sources https://github.com/Freescale/gstreamer-imx dependency is GitHub - Freescale/libimxvpuapi: i.MX VPU API Library . Could anyone please explain how this work
Labels (4)
joanxie
one can use gst-inspect vpuenc to find all of dependencies, I don't find encode/deimx-vcoder, maybe you should use software to use this.
anjojohn
Hi Joan,
"encode/deimx-vcoder" is typo error, was meant to encode/decode. I was expecting how the software flow works in vpu encoder/decoder when gstreamer is used. Like i said i found libimxvpuwrap and libimxvpuapi libraries. which one gstreamer uses ?
