Is there a product page specifically for the MPXH6101A6 parts? I keep getting linked to the MPX4101A page.
larry
Please send the correct link.
reyes
Thank you for letting us know about this issue, I will report it to the web team to try to solve this problem, meanwhile, you can access directly to the MPXH6101A Datasheet and some of Application notes related to this pressure sensors using the following links:
MPXH6101A Datasheet: http://www.nxp.com/assets/documents/data/en/data-sheets/MPXH6101A.pdf
Applications Notes:
AN936 – Mounting Techniques, Lead Forming, and Testing of the MPX Series Pressure Sensors: http://www.nxp.com/assets/documents/data/en/application-notes/AN936.pdf
AN1984 – Handling Freescale Pressure Sensors: http://www.nxp.com/assets/documents/data/en/application-notes/AN1984.pdf
AN3150 – Soldering Recommendations for Pressure Sensor Devices: http://www.nxp.com/assets/documents/data/en/application-notes/AN3150.pdf
AN1646 – Noise Considerations for Integrated Pressure Sensors: http://www.nxp.com/assets/documents/data/en/application-notes/AN1646.pdf
I hope this helps.
Jose
