Hello!
When I use the library function EEPROM_Program1Byte to write a byte to MKE02Z64VLD4's EEPROM, it can be successful at first two times after erase sectors, the third time has error FLASH_ERR_MGSTAT0. How to solve this problem?
I found that it must erase the sector before using EEPROM_Program1Byte every time.
