Copy Functions from Flash to Ram (In Software programming)
matthiasgroenin
I would like to reprogram my lpc54101 over UART without using the Bootloader (the hardware design does not allow me to run the controller into bootloader mode).
How can I run the necessary functions for writing the flash and using UART from the ram? How to copy these functions.is there anything like "_ramfunc"
Is that even possible or the correct way?
Thank you for any help!
matthiasgroenin
Thank you for your support,
I am using IAR Embedded Workbench. Do you have some specific help on that one?
Kind Regards
lpcxpresso_supp
Using which toolchain? If LPCXpresso IDE, see https://community.nxp.com/message/630746
LPCXpresso Support
